Bought a 30 day plan. Forgot to add Global Texting.
xzoto1
Is there any way to add Global Texting to my existing plan? Not only do I need it, it also costs less for that plan as it's a bundle.
1 REPLY 1
will13am
@xzoto1, you will need the help of the moderator team to make the correction to your plan.   The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
