Block porting / Require verbal confirmation
Sandy_C
While I maintain unique passwords & security questions across my online accounts, I would like to add the security of NOT allowing my number to be ported without my verbal confirmation.
Does Public Mobile offer the option of requesting a verbal confirmation before allowing my phone number to be ported to another telco?
@Sandy_C
Regarding porting...see processes and helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
@Sandy_C  this is a system process.  SMS reply within 90 mins is the confirmation the system need to get.  adding verbal confirmation cannot be done.
@Sandy_C
As described by @Anonymous  this is the newly implemented (earlier this year) industry standard for porting authorization. Your request would be impossible at pm as there is no phone support. You can initiate a port request by calling the telus porting department but a phone number still will not be released without replying YES within 90 minutes to the porting authorization text.
The account needs to be active, the SIM needs to be in a phone, the phone needs to be on and connected to here not in airplane mode, upon a port request - the system sends an SMS text to that SIM whereupon the recipient needs to reply YES to the text inside of 90 minutes to let the port go ahead.
Is that not sufficient? You sound pretty up on security and your privacy so this is good to know your opinion.
