Blacklist a phone
RS27
I recently lost my phone and need to have it added to the blacklist. I have the IMEI number and everything. Can someone get in contact with on how to proceed. Thank you.
1 REPLY 1
@RS27
Please contact PM Support and ask them to help to add the phone to the blacklist:
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
Also, use the FindMy service to try to locate the phone or remove wipe :
Apple: https://www.apple.com/ca/icloud/find-my/
                 (how to use: https://www.pcmag.com/how-to/find-a-lost-iphone)
Google: https://myaccount.google.com/find-your-phone
Samsung: https://findmymobile.samsung.com/
               (how to use: https://www.pcmag.com/how-to/how-to-find-a-lost-android-phone)
