06-03-2024 12:54 PM
Hi,
On my last bill there were 3 amounts that were listed:$5.75 on May3, $11.50 on May 9 and $17.25 on May7. I expected the first 2 amounts, but I didn't expect the third one of $17.25. Can an agent please explain that extra amount. Thanks.
Payment
06-04-2024 09:53 AM
Thank you for your rapid response. You have been very helpful.
06-03-2024 02:07 PM
You were *force migrated* to the (universally bad) Points system at some point so no more benefits from the old Rewards system.
15 points required for $15 bill credit.
- Sign in to https://myrewards.publicmobile.ca
- Browse Catalogue
- $15 Bill Credit
06-03-2024 01:02 PM
HI @foffe
so, you have 2 accounts with PM and not 3 ? did you make a plan change on May 7?
since it is account payment issue, you will have to check with PM support agent and ask them to confirm
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
