Better service
whitbyphone
  • I want the $40 for 15G promo plan. My account said too many attempt to login
gpixel
@whitbyphone
try logging into your self serve at least once every 2 months or this will keep happening to you. you need to reset your password. after resetting the password you will need to use a incognito or private mode to login to the website.
mimmo
Wait an hour and try logging in. If needed try the reset password
Yummy
You tried to log with incorrect id/pass too many times.
You should wait at least 1 hour and try to log in again. Do not change password too many times as it will not help.
JK8
@whitbyphone
You should try again in a little while. Clear browser cache and go incognito.
