Best way to get my $10 plan to $0 every month
ap45
7 REPLIES 7
jor123
@funpig wrote:
Cut a couple Big Macs each month.
The easiest answer.. Smiley Very Happy
funpig
cavemantoronto
It is very easy to get $10 plan for free.  Autopay, refer a few people, spend a little time here answering questions and you're set.  More expensive plans are more challenging to get free.
LovesToPM
hi @ap45
Great thing about Public Mobile. You get to pick.
Here are some examples
  • $2 AutoPay + 8 referrals
  • $2 AutoPay + $2 Community reward + 6 referrals
  • $2 Autopay + $1 loyalty after one year + 7 referrals
  • $2 Autopay + $5 loyalty after 5 years + 3 referrals
The longer you stay, the more rewards you will earn.
You can read up on Reward Rules here
The Community Rewards are generally non renewing and must be earned each month.
geopublic
@ap45  Easy, you just need 8 referrals and enable AutoPay.
The $2 is easy. Get lots of referrals...a little more work. Participate quite a bit here with helpful replies each month...more work. Remain a customer for years and get another buck per (up to 5)
iliketotalk
@ap45 hi get active in the community refer some friends pay with auto pay to name a fewSmiley Happy
