04-10-2024 04:18 PM
Wanted to change my monthly plan..I'm a big texter and I don't call out alot. I don't need alot of internet. I have wifi at home. At work I only used my data for spotify. Anyone have a good suggestion which plan works for me. I don't know alot about data plans or how much a GB so girl needs help please and thank you
04-10-2024 04:30 PM
you'd be fine with a $15 or $25 plan, depending on how much data you really need and outgoing calls. But as you mentioned if you dont need much, id go with the $15 plan, you can always switch up to the $25 after a month if you feel you need more (they may also send you a better promotional plan rate too)
04-10-2024 04:26 PM - edited 04-10-2024 04:28 PM
all the current plans include Unlimited International texting so you're good to go. You just need to decide on talk/data requirements...but from the looks of things, the $15 plan would work for you. Data and costs go up from there...$25 has 1GB and so on. I use the $15 plan as I need very minimal data too.
