10-07-2016 09:04 PM - edited 01-04-2022 03:38 PM
11-23-2016 12:59 PM
@Mary_M I am also having this problem and I have emailed twice with all my information. They say I should recieve a response in 48 hours and its been 4 days now since the first email. I can call out, recieve messages and use data but can't recieve calls, they go to my bell voicemail.
11-23-2016 06:45 AM
11-22-2016 04:01 PM
Hi Mary,
I am having the same issue. I sent you a PM last week.
Thanks!!
11-22-2016 03:07 PM
Hi @Mary_M,
Thank you for getting back to me. I understand how busy it must be with the new promo. My phone is now fully functional, thanks again for all of the help!
T
11-22-2016 01:32 PM
Hey @taniaz
Thank you for your patience 🙂
You port has been completed, please refer to my private message! Welcome to PM,
Mary
11-15-2016 10:34 PM
Thank you for the response, at least my old SIM card works for now.
11-15-2016 08:44 PM
11-15-2016 06:38 PM
Hello!
I am going through the same issue even though it said the port was originally successful. I then got a text from PM saying asking to send a contact request to provide the correct ESN/MEID from Bell, which i thought i had already done. I submitted the request and private messaged the moderators. Do you know how long this will take to resolve?
Thank you for your help
10-08-2016 12:27 PM
10-08-2016 12:24 PM
Everything is working fine now. Thanks @Mary_M
10-08-2016 11:34 AM
Thank you, @Mary_M! As always, you rock!
10-08-2016 10:51 AM
Hey @karenbruiners, I just switched over from Bell as well. The switch, for me, went smoothly with the exception of voicemail (I could get VM, but couldn't access by long-pressing 1 anymore). Anyway, the moderator (PM staffer) was very helpful in solving this issue, and I'm sure they could help you with your call issue as well. Good luck!
10-08-2016 09:31 AM
Good morning @karenbruiners
Welcome to Public Mobile!
I have received your private message and I will work on your case shortly.
Once I process the port, I will be sending you a confirmation.
Thank you,
Mary
10-07-2016 09:45 PM
@fktw yes that's typically how the ports go when transfering from another wireless provider... they usually complete within minutes. In some cases, the port request is rejected by the other provider. Usually it's because the port request page is a bit confusing and people may not fill it out correctly, thus the info doesn't match what's on file at the previous provider and the request is rejected by their system. Another less common cause is if your account is not still open and in good standing (you haven't made the mistake of calling them to cancel, and you don't owe them any money) the request will fail also.
Our community moderators @Shazia_K, @Mary_M, and @Saray_O are PM staff with the ability to look in the backend systems to see what the cause of the rejection was, and can resubmit on your behalf once they get the correct info.
10-07-2016 09:38 PM
I just ported my number in last night and the same thing occurred, except it took only 30 minutes to complete the dialing in portion. Once that got resolved, I got a text message from PM telling me the port is complete. If you haven't received that text, then it's likely stuck somewhere in the system.
10-07-2016 09:36 PM
I don't think Shazia is working this weekend, based on a private message she sent me this afternoon. But yes @karenbruiners please send a private message to both @Mary_M and @Saray_O and include:
1) your temporary public mobile phone number that you activated with
2) mention it's bell you're transfering from
3) the account number you had at Bell
4) the phone number you are trying to transfer over from Bell to Public Mobile
They can resubmit the port request for you in the morning, and once that's done it should be fairly quick after that.
10-07-2016 09:29 PM
10-07-2016 09:14 PM
It shouldn't have taken that long, most likely there was an error in number port. As @NDesai said, your Bell sim card should still be active until the number port request is completed.
PM staff will be online in the morning. Send your Bell account number, PIN, Bell phone number and the name on the Bell account via a private message to @Mary_M / @Shazia_K / @Saray_O right now or wait for one of them to reach out to you in this thread and then communicate further.
10-07-2016 09:10 PM
10-07-2016 09:10 PM
10-07-2016 09:07 PM
Have you tried removing the sim and rebooting your phone? Did you check if your bell sim is still working? If its working, i suggest you to wait little more.
If still the same issue, staff member will complete the porting process tomorrow.
10-07-2016 09:06 PM
Hi @karenbruiners!
Welcome to PM!
This is normal while the number port request is in prgress. How long has it been?
It usually takes from 30 minutes to 2 hours.
Have your restarted your phone since submitting the port request?
