Autopay rewards
08-21-2019 02:40 AM - edited 01-05-2022 06:32 AM
I have been with PM for 3 30 day plan cycles now with autopay set up but have not received the $2 off autopay reward yet.
Help.
Joining Public
08-21-2019 03:14 AM
As you can see no rewards are being applied and nothing is in the transaction history.
I have contacted the mods so we'll see what happens.
08-21-2019 03:07 AM
@itsawesome1234If you scroll up higher and if you are not on your day of renewal you should see it.. eg
08-21-2019 03:06 AM
You should contact Moderator team like Caveman said in above, but before you do that you should also check your account transaction history to see if the $2 was applied but not posted in your rewards page - in case they gave you the credit but it not showing on the rewards page, that's happened to me for the community rewards where my account transactions show I got the rewards but my rewards page doesn't show it.
08-21-2019 02:58 AM
As you can see below I have autopay active but no rewards have been earned.
08-21-2019 02:43 AM
@itsawesome1234 wrote:I have been with PM for 3 30 day plan cycles now with autopay set up but have not received the $2 off autopay reward yet.
Help.
Go to self serve. Does it say you have $2 autopay reward. That should go to balance before each renewal. If not, contact moderators using https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
