06-01-2020 12:00 AM - edited 01-05-2022 10:59 AM
So time here is 9:55PM on GMT-7 aka MST, which is where I currently live, when I toggle ON Automatic Date and time, it sets the time to 10:55PM on GMT-5 aka Central daylight time. Is there any way I could rectify this issue, since it messes up text message timestamps and etc.
Newly came to PM from Bell btw.
Samsung Galaxy S7
06-02-2020 08:17 PM - edited 06-02-2020 08:28 PM
@CooLTanG wrote:S7, worked completely fine with Bell provider last month.
Have a look at this link and possibly consider trying the last 2 options listed.
https://www.theandroidportal.com/fix-automatic-time-zone-and-dateclock-are-wrong-on-android/
Edit: Just consider the last option. Do not try the battery removal.
06-02-2020 08:06 PM
@CooLTanG take a screenshot of that menu where your automatic options are. maybe it's the sim causing it. have you tried removing and reinstalling it?
06-02-2020 08:05 PM
06-01-2020 04:57 AM
@CooLTanG what type of phone are you using?
06-01-2020 03:15 AM
Tried all the above to no avail, I don't want to use manual because messages end up looking like this aka:
4:45pm Buddy: Hey (msg recieved at 5:55pm)
4:46pm Buddy: what ya doing? (msg recieved at 5:56pm)
5:55pm Me: Hey
5:56pm Me: Nothing
This is just how the messages look in the app.
06-01-2020 01:52 AM
@CooLTanG turn your location on and toggle from automatic, to manual and then automatic again. if that still doesn't change it, then just manually change it on your phone.
06-01-2020 12:49 AM
Try restarting phone or flipping in/out of airplane mode.
06-01-2020 12:45 AM
@CooLTanG Check the timezone setting to make sure it's not manually set.
06-01-2020 12:01 AM - edited 06-01-2020 12:55 AM
@CooLTanG wrote:So time here is 9:55PM on GMT-7 aka MST, which is where I currently live, when I toggle ON Automatic Date and time, it sets the time to 10:55PM on GMT-5 aka Central daylight time. Is there any way I could rectify this issue, since it messes up text message timestamps and etc.
I would simply set the time zone of your device to manual, while ensuring that the correct one is selected.
