06-26-2021 06:46 AM - edited 01-06-2022 02:56 AM
I am registered for Auto Pay and payment did not process this month.
Payment
07-01-2021 09:38 AM
Thanks esjliv Mayor / Maire your link, I get problem solved by moderator reply, thanks again the help.
07-01-2021 08:16 AM
@sugarorange6 wrote:I already registered for Auto Pay and payment did not process this month.
I have balance in my account and now also disappear, I had add $1 last night, the credit card number can go through, the credit card is good.
Please fix my auto pay, and my monthly plan, thank you very much.
Hello @sugarorange6
Do you still have services? If yes, this could be your account going through the normal renewal process. The SELF SERVE account can say "expired" or "suspended" on the day of or before your plan is due to renew. So if this is the case, ignore these messages on your SELF SERVE account.
If you have no services, and it is past your renewal, maybe your autopay failed?
- Add Funds to your Plan Amount through SELF SERVE (or by calling 611 if you have a card registered)
- Go to “Plan and Add-Ons” TAB
- Select "Lost/Stolen Phone" TAB
- Select "Suspend Service" BUTTON
- Then, Select Resume/Reactivate Service
- Reboot your phone.
If this was an Autopay failure, I would let the Moderators know. And, also ensure all rewards were provided to you.
To contact the Public Mobile Moderator_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
07-01-2021 08:10 AM
06-26-2021 10:09 AM
@dipiperni wrote:Problem resolved!
Good news indeed.
So what did you do to resolve it ? What steps did you take to get it going ?
06-26-2021 08:48 AM
Problem resolved!
06-26-2021 08:07 AM
@dipiperni wrote:I am registered for Auto Pay and payment did not process this month.
Hello @dipiperni ,
Autopay should not fail if you have a valid credit card on the account, but alas, there are reports of it.
I hope you were able to make a payment and get your services back.
I would let the Moderators know of the failure.
OR
06-26-2021 07:43 AM
Sometimes autopay does fail and has some glitches. To prevent this, I usually pay for my service manually when I get the notification that a payment is due. That way it prevents anything like this happening. You can always call 611 and make a payment.
06-26-2021 07:41 AM - edited 06-26-2021 07:43 AM
Log into selfserve and try a manual payment. If that fails then I would delete the credit card on file (click payments then look at bottom of screen for something like manage cards or something similar.
If none of that works buy a voucher and use that to pay then contact mods to investigate
Edit you can also try calling 611 and see if you can make a payment using your pre registered credit card.
