Auto Pay/Pre Authorized Payments
serwoo
for the 15$ phone plan with pre authorized payments, would you get 250mb each month of data AND 2$ off every 30 days?
(ie, a 13$ plan with 250mb data)?
7 REPLIES 7
will13am
@serwoo , on top of what everyone else has mentioned, each full year of service results in a loyalty reward of $1 per renewal up to $5.  Five years from now, you could be paying $8 for each renewal with full loyalty and auto pay rewards.
popping
Correct.  You pay $13/30days with 250MB data with autopay enabled.
@serwoo
Please note that PM always want us to pay full plan cost during activation.  But your will get a $2 credit as your available fund in your account.  On your first renew date, you will get another $2 autopay discount.  Therefore, your second payment will be $15 - $4 = $11.
If you activate your account with a refer-a-friend code from your friend, you will get $10 credit.  With the refer-a-friend credit + autopay credit, you will be paying only $1 for your second 30 days cycle.
hairbag1
@serwoo...a bit off topic but ...the $15 plan has limited Canada wide calling. You can also get a 500 minute Canada wide calling add-on for $5...that's right...just $5.
Any unused add-on minutes will just keep rolling over, month to month until you use up 500 minutes.
It's a great add-on for a limited calling plan like yours. Welcome to Public Mobile.
@serwoo every 30 day cycle, not per month. Stay safe. I'm on the same plan. To save more,  you can add the TextNow app and use it over WiFi to make/ receive/ send calls and texts within Canada and to and from the US for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter it followed by #  - and you are in your voicemail account - Hang up when you are finished. No minutes used.
Also, if you haven't activated yet.  Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
@serwoo You are correct!!
$13 plus applicable taxes.
If you signed up with a referral code your 2nd month will have $10 off = $3...not bad eh?
RossN
@serwoo hi if you add a credit card you will get 2 dollars off per cycle plus 250 mb
popping
