Asus ZenFone 3
05-06-2017 01:40 PM - edited 01-04-2022 01:45 PM
Hey everyone just got a Asus ZenFone 3 and for some reason I can't get the internet working, I have set up the proper apn settings but still doesn't work please help!
Phones
05-06-2017 10:03 PM
05-06-2017 09:56 PM
Model compatibility would affect the ability to connect to LTE. All zenfone 3 models should at least work on 3G. So, I would start by checking the APN settings to make sure they are correct (see link below). Create a new APN is necessary. Then, I would check to make sure that data is enabled. Finally, I would check that data usage has not reached the set limit. Report back if these checks do not restore data.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
05-06-2017 02:14 PM
First check if your phone is compatible with lte network with public mobile
http://willmyphonework.net/
Check the link and see all the required frequencies is there
05-06-2017 02:02 PM
Try re-booting ?
