03-22-2024 10:17 PM
Hey y'all - I am currently experiencing an issue with the app - it won't let me log out.
Would the best bet is to just delete and re-install the app?
It just puts me on this animation for a long time (Internet isn't the issue speed plan is on 500mbps on TELUS PureFiber)
Wednesday
My laptop browser won't let me log out
03-02-2025 12:02 PM
mine won’t let me log out either. They did an update that I downloaded because I was at Ace three with $57 billion after the update I downloaded everything’s changed around. The screen was different said hit continue to the next page. There was nowhere to shut that down so when I hit it, it dropped me down to Jack one with $2 million took me a long time to get that $57 billion of contacted Support three times and never got a response back
03-22-2024 10:42 PM
Yikes! That's no good. I hope it's s one off.
03-22-2024 10:41 PM
@hTideGnow - Thanks - Just uninstalled it and it fixed the issue!
03-22-2024 10:38 PM - edited 03-22-2024 10:43 PM
@hTideGnow - I am going to uninstall and re-install it.
EDIT: Ha, when I uninstalled and re-installed the PM app it asked for my location always? I just set it to only while using.
03-22-2024 10:38 PM
@Sansan - It was roughly 30 minutes of waiting on that screen.
03-22-2024 10:30 PM
HI @fixin
I think yours is iPhone? if it is Android,you can clear data
worst case just unintsall and reintall 🙂
03-22-2024 10:23 PM
Try again in a few minutes. It shouldn't require you to un install. But after about 30 minutes if it doesn't allow you to log out, then yea have to delete and reinstall.
