Angry
Runt70
I'm not receiving calls. They only go to voicemail. Also when I make a call. Sometimes I have a signal and sometimes I don't.
2 REPLIES 2
slusagm
did you try Reboot phone and Reset network settings?
and someone reported data issue in Ontario near Hamilton this morning.  If yours is voice, it might not be related, but just in case
hi @Runt70
are you in Manitoba?  if you are , what phone  you have?
Manitoba has started removing 3G networks there.  It will affect voice calls.  Only phones that is on PM's VoLTE whitelist can use VoLTE for voice, or they will lose voice completely
use the IMEI checker to confirm if your phone makes it to the list
https://www.publicmobile.ca/en/get-help/articles/volte
