2 hours ago
I fell victim to the cheaper option...but the account transfer from my previous carrier to Public has not gone well. If you are thinking of switching to Public...please reconsider. I am sure the transfer works for some...but there is a much greater than 0% chance that it won't go well for everyone. If you want to ensure your number stays the same, please consider staying with your current carrier.
53m ago
A quick update. Things are indeed going worse. As what seems to be a Hail Mary, they've asked me to reset my network settings...which will erase all Wifi passwords, and it didn't not fix the original issue.
I can stress enough..proceed with your eyes wide open prior to switching to Public.
an hour ago
I do. Thanks for taking the time to respond. I do have a physical SIM...but my phone seems to report that "Public Mobile has turned off LTE calls".
Everyone, please reconsider transferring to Public.
an hour ago
To keep everyone updated. As the help processes also seem to be immature, I'm not sure where I am..though I feel I'm farther along...though, I now have a message that says "Public mobile has turned off LTE calls on your account".
I can't stress enough...exercise extreme caution.
2 hours ago
the issue was not a port problem but am eSIM setting up issue
there are in fact more problems with eSIM than porting
so, you have physical sim now? you can call the porting team to confirm if the port is done, you have the number?
2 hours ago - last edited 2 hours ago
@Travis111000 Using the IMEI was probably the issue it’s best to ignore it and just use the old providers account number instead .
2 hours ago
The process started out great. I selected my plan, they took the appropriate amount of money. When I started the process, I selected "transfer my number". I entered my appropriate account an IMEI number, and then received a message saying "Unable to import eSIM". I started up a help ticket, and they asked for all the information again, and sent a QR code. I attempted to use the QR code to import the eSim...but the same error message came up. I was instructed to go out and purchase a physical SIM. I did that, and now I'm on hold with the porting team.
2 hours ago
i agree with @Travis111000. i had such a terrible experience transferring as well. and they gaslight you saying it's users' problem. the transfer should be done within minutes but I've been dealing with it for more than 4 hours. yet the team is still asking me to wait 2-3 hours without a solution.
2 hours ago
what exactly was the problem with port?
2 hours ago
Again...absolutely...as I've said before, I'm sure the process works for most. And to your point, I don't agree...it isn't necessarily a user problem with the Public staff...I'm sure they are working with a process that hasn't been properly QAed and matured.
As slusagm mentioned, the process likely works well for many...but not all. Please beware.
2 hours ago
most transfer worked well. Many transfer issue was in fact a user problem
so, you had problems with yours
2 hours ago
Again...a word of caution before moving over to Public. The transfer, I'm sure, works well for most. But not all. There seems to be a greater than 0 chance you won't be able to keep your number if the process to transfer doesn't work. On top of the chance of not keeping you number, please ensure you have a large portion of your day free to handle the manual process.
Please, re-consider moving to Public.
2 hours ago
I have received the number. Thanks Handy!. I received a message saying that a transfer request has not been received for my phone number.
Again...I'm sure this works well for most...but not all. Please use caution...and if your number is important to you, consider not transferring to Public.
2 hours ago
Thanks. As mentioned, I'm sure this works well for most...but definitely not all. I'm just saying that people should manage their risks. If it is important to keep your number, you are not gauranteed to do that if you transfer to Public.
2 hours ago
@Travis111000 wrote:My experience is exactly as you outlined...other than there was an error with the eSim (note: I had an eSIm with my previous provider). I have been instructed to by a physical sim for Public (which is a bit ridiculous in 2024). My phone still has not been activated.
Again, I am sure this process works well for most...but if it is important to you to keep your number, I would advise against the transfer to Public.
I tend to disagree, but respect your opinion. I ported over to Public 6 years ago and had zero problems. And there are two options, SIM card or eSIM. BOTH have to be offered because some phones don't offer eSIM options. These two options are offered by all telco services. If you need a physical SIM card, here are two options to get it faster.
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
2 hours ago
2 hours ago
@Travis111000 Both accounts need to be active for successful number port / transfer . Leaving old providers sim in the phone and start the port request with new provider . You should get text on old providers SIM card to confirm the porting the number by replying YES . And that should be it for most . If you have any issues you can try the porting team or contact support directly . In most cases any hiccup can be fixed is one does experience a hiccup
