Amazon firephone compatibility with Public
Mike2015
I just bought Amazon 32GB fire phone GSM.
Is it compatible with Public's network.
Per Specs here are the compatiblity specs:
UMTS/HSPA+/DC-HSDPA (850, 900, 1700/2100, 1900, 2100 MHz), Quad-band GSM/EDGE (850, 900, 1800, 1900 MHz), 9 bands of 4G-LTE (Bands 1, 2, 3, 4, 5, 7, 8, 17, 20), supports carrier aggregation
http://www.amazon.com/dp/B00OC0USA6/ref=nav_shopall_k_phone_unlocked
Thanks,
Mike
bilal
Yes, a friend of mine is using it. 100% confirmed to work on Public Mobile.
Martin
Legend
Legend
Hello Mike,
Based on the specs provided, it's fully compatible with Public Mobile's requirements.
Cheers.
Ali
Hello Mike
Amazon 32GB fire phone unlocked GSM should work with Public Mobile.
