Always need to put country code in calls
Options
08-10-2023 12:33 AM
Hi , I have an iPhone 8 and even for local calls I need to add the country code, otherwise the calls fails.
is there a way to solve this?
Labels:
Service
2 REPLIES 2
Options
08-10-2023 01:20 AM
Is the number in your contact list in your iPhone?
You will need to add 1 in front of the area code.
Options
08-10-2023 01:00 AM
When you put your SIM Card into another Device is the issue persistent?
