Alert Messages from US Bank not getting received
easy2go
Hello Friends,
Does any one faced a similar issue and resolved this. Banker is saying thats something with the Provider has to remove the blockage. I can receive text messages from my friends in USA. Kindly advise for any help. Thanks for your assistance in advance.
Thanks.
darlicious
@easy2go
Depending on when you activated and ported in? You may not recieve some finance related 2FA text messages for 72 hrs up to 7 days. If it goes beyond that time you may need to see if the financial institution offers verification thru email or voice message.
HALIMACS
@easy2go
Good question.
Check out this link re short codes:
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/What-short-codes-are-supported-by-Publi...
If you wish to ask customer support, here's how:
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
@easy2go
please note that international system text like 2FA might not get through.  A lot of the time it is the sender issue, rather than the receiving end.  The sender system was not setup to send text , shortcode, outside of their home country.  As far as I know, PM does not actively setup brokerage for this.   I doubt there is much PM will do, but you can try to open ticket with them
Also, I suggest you to ask your US bank for other from of 2FA.  Authentication app will be best, email or voice call will be a workarounds
You can open ticket with PM support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
