Ads after calls
11-18-2022
02:17 PM
11-18-2022
07:56 PM
computergeek541
Whenever I make a call I see an ad afterwards. How do I deactivate that? Also text is supposed to be included in package yet the text app I have also shows ads. How do I get the right text app that is without ads?
Phones
07-14-2024 08:29 PM
did You ever get an answer I have the same problem
11-19-2022 11:42 AM
Can you find the About page somewhere in the app? My Samsung dialer does not mention Samsung. TextNow about says TextNow.
Was the phone a used phone when you got it? If so, I would have done a factory reset on it.
Is the operating system original or did somebody root it and put on a different system? If you can run Google Wallet then that might indicate that it's not rooted.
11-19-2022 11:21 AM
Okay I switched to using Messages, sms, now for text which is the default one in my Android Moto 5, I think.
As for the phone app, I have been using the seemingly default, old fashioned phone receiver icon one .
11-18-2022 02:22 PM - edited 11-18-2022 02:27 PM
Sounds like you're taking about Text Now and not Public. That's why I don't use Text Now for all those ads and such.
So the right text app to have without any ads popping up, is one that you pay for!
Don't go for the free ones.
11-18-2022 02:19 PM - edited 11-18-2022 02:20 PM
Impossible if you are using your phone's native phone and SMS app.
Ads do appear if you use free voip apps (TextNow and similar).
11-18-2022 02:19 PM
@toddmatheson , what app are you using as your default calling and text app. Ads are under your control, Public Mobile does not have any skin in that game so to speak.
