Additional sim
Nishanth909
Hi
I would like to use a sim card for GPS tracker. Do u have any economic packages to add a sim with minimum data package per month
@Nishanth909
PM does not have data only package.  Depends on your data need, the $15 comes with 250MB and that is the cheapest one yo can get
If you need more data, you will have to get the $25 plan and you will get 1GB with Autopay enabled.
BeachNBeer
@Nishanth909 PM does not offer just data packages. Their cheapest plan is $15.
