Additional Data Purchase
spearo
What are the options for purchasing additional data or services while in the United States?
DDM69
2023-05-24 22_46_45-Canada's First 5G Subscription Phone Service _ Public Mobile.png
HALIMACS
One caveat,  @spearo
If you already have a US roaming add-on in effect, and wish to purchase another same one after it expires, you have to wait 24 hours after the initial one is done before applying the same one again.
The only way to avoid this is having customer support add it for you or selecting a different US roaming add-on.
To contact a Customer Support Agent, send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
@spearo
You have two 15 days USA Roaming bundle options:
$15 for unlimited text and talk or $30 for unlimited text, talk and 3gb data.
Or switch to the Canada/USA plan.
I personally use the TextNow SIM for unlimited calling and texting in 5G without the need to connect to WiFi.
US raoming data-add-on infromation can be found at:   https://www.publicmobile.ca/en/on/plans#ALL
The other opotion option would be change to a plan that includes US roaming.  Those are advertised as Canada-US plans.
