11-07-2016 08:00 AM - edited 01-04-2022 06:06 PM
Can I add my wife who doesn't have a cell number yet but I am planing on buying one from Best Buy?
I want her to have her on plan but I will pay for it from this account.
DD
11-07-2016 09:02 AM
Thanks to all of those who replied. I will create a seperate account.
11-07-2016 08:41 AM
11-07-2016 08:38 AM
Everyone who has replied thus far, is Correct
To sum up in one post:
11-07-2016 08:29 AM
Just make sure you get a Koodo/Telus or an unlocked phone. As others have mentioned you will need to create a new account for your wife but you can just set it up to autopay with your credit card.
11-07-2016 08:14 AM
Your best bet for a phone is to look online for an unlocked or a Telus/Kodoo locked phone. Buying a brand new unlocked phone can be very expensive but finding a used one you can get some good deals.
11-07-2016 08:11 AM
Each phone line requires a seperate account. You can not have 2 lines on one account.
If you want your wife to have this promo, just buy her a sim card and activate it under your name on a second account. You don't need a physical phone in hand to have an active account.
11-07-2016 08:08 AM
It is also two seperate accounts. So you must create an account for her as well
11-07-2016 08:04 AM
PM has no physical store presence, nor as far as I recall, do they have any deals w Best Buy or any retailer, PM is essentially an ONLINE Virtual Carrier, No Call Centers, Just email, Community and private message support
11-07-2016 08:02 AM
You can do all that, It's all done all online, You JUST need a Compatible handset, and a PM Tri-Sim, That's it
