Adding US Call add-on to my account
06-05-2017 06:14 PM - edited 01-04-2022 01:50 PM
06-07-2017 04:32 PM
06-05-2017 09:23 PM - edited 06-05-2017 09:26 PM
I think calling 611 is available only when in the home zone at the moment. Public Mobile is apparently working on enabling 611 while in the US. The only purchase option is online. The Public Mobile self serve portal should be accessible from the US.
http://productioncommunity.publicmobile.ca/t5/Announcements/U-S-Roaming-has-arrived/m-p/94947#U94947
06-05-2017 09:16 PM
What error are you getting when trying it on 611? So they can fix it, probably the same issue as before.
As for buying on self serve, sometimes it work in one try. If the old glitch happens again, you need to buy one more time after the fund is in it.
06-05-2017 06:33 PM - edited 06-05-2017 06:38 PM
