08-22-2018 08:23 PM - edited 01-05-2022 12:38 AM
Dear ones,
I am facing a problem in taking add on of 200mb data pack for $10. Even though I have sufficient balance in my account but I cant go for add on. I tried online and even I tried by calling *611. But my problem is not solved yet. Can anyone help me in this regard
08-27-2018 11:58 AM
@akshaysm11 wrote:yes I was end with the 30 days cycle and was looking for some add ons for 3-4 days. I want to recharge my next cycle bit later so I wanted a add on till that.
@akshaysm11 sorry I've been away a few days but yes that's not possible unfortunately. 😞
08-23-2018 06:20 PM
08-23-2018 04:30 PM
@akshaysm11 wrote:my 30 days pack get expired so i am going to have add on of 200 mb for few days. but i am not able to do that
@akshaysm11 oh this might be the issue. Just to be clear--are you saying that you ran out of data and need the add-on to get to the end of your current 30 day cycle? Or are you saying you're already past the end of a cycle and your plan is suspended but you're trying to puchase an add-on?
If it's the 2nd thing I mentioned, you can't do that unfortunately. Add-ons only work with an active base plan in place.
08-23-2018 04:04 PM
08-23-2018 04:00 PM
its not working too
08-22-2018 09:29 PM
@will13am wrote:@akshaysm11, for the online purchase, it is two steps. Step 1 puts the cash into the account. Step 2 you go back and try to buy again and this time the cash in the account is applied to buying the add on. Try it again online.
Have you tried this @akshaysm11....this should work!
08-22-2018 08:27 PM - edited 08-23-2018 12:11 AM
@akshaysm11, for the online purchase, it is two steps. Step 1 puts the cash into the account. Step 2 you go back and try to buy again and this time the cash in the account is applied to buying the add on. Try it again online. Here is an illustration on how the two step add-on purchase works.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
