Add ons
dejakef
I want to buy a Canada -Us 15 day add on for talk and text only.  I can't see how to do this on the website.  There is info but nothing to click to get one.
Jedi1
If you happen to be on the points system and have points available, the add-on is also available with points, 10 pts for the talk and text.
Runningman1990
As mentioned above on how to find the US text and talk for $15.  I would suggest to go for the $30 for text and talk and 3gig of data. You will need data in the states or wherever you go. It is a bit more, but sure comes in handy. We were just in Vegas and use our Public Mobile $30 text and talk and 3g of data. Worked flawlessly - was able to call back to Canada, texting was great.  Used data for the Google Map and while walking around - if you need to look up anything. Just nice to have data, just like home!
Phil_Adelphus
@dejakef  On the website when you first log in there is a welcome message with your name.  Beside that are links to add-ons and to change subscription.  Select the add-ons and you will be taken to a page to "Shop Add-Ons", then you can make your choice there.
HI @dejakef
are you using app or browser?
login to My Account and click Buy Add-ons from top of the overveiw page
or you can go to Subsciption & Add-on page to buy
@dejakef  Go to subscription add on page
