01-16-2019 04:57 PM - edited 01-05-2022 03:04 AM
Does the add for US long distance calls ($8.00 for 200 min US & CAN) allow me to make calls to the US from Canada and also to make US calls while in the US AND call Canada while in the US?????
01-17-2019 03:26 PM
@nbrocksailing wrote:Thanks for taking the time to answer...got it!
Happy to help! @nbrocksailing, please mark the comment that best answered your question with the 'solved' button ![]()
01-16-2019 08:04 PM
01-16-2019 05:02 PM - edited 01-16-2019 05:04 PM
@nbrocksailing wrote:Does the add for US long distance calls ($8.00 for 200 min US & CAN) allow me to make calls to the US from Canada
@nbrocksailing wrote:make US calls while in the US AND call Canada while in the US?????
No. You need U.S. roaming (10-day) add-on for that.
01-16-2019 05:02 PM - edited 01-16-2019 05:05 PM
@nbrocksailing wrote:Does the add for US long distance calls ($8.00 for 200 min US & CAN) allow me to make calls to the US from Canada and also to make US calls while in the US AND call Canada while in the US?????
No, the add-on only works to call the US from Canada, not to make any calls from the US. You'll need a US roaming add-on for that. See table here 🙂
EDIT: Here's the table so you don't have to click (see the bottom row for what you'll need to make calls from the US).
Long Distance and U.S. Roaming Add-Ons
| Making a Call to someone in Canada | Making a Call to someone outside of Canada | Answering a call from anywhere in the world |
In Canada: Province-Wide | Please refer to above table. | Requires Long Distance Add-On. | Uses plan minutes. If your minutes have been used, time will be taken from your Long Distance Add-On minutes.
In Canada: Canada-Wide
| Uses plan minutes before Long Distance Add-On minutes. | Requires Long Distance Add-On. | Uses plan minutes. If your minutes have been used, time will be taken from your Long Distance Add-On minutes. |
In Canada: Canada-wide and to the U.S.
| Uses plan minutes before Long Distance Add-On minutes. | Excluding calls to the U.S., you will require a Long Distance Add-On. | Uses plan minutes. If your minutes have been used, time will be taken from your Long Distance Add-On minutes. |
In U.S. | Requires a U.S. Roaming Add-On with Talk included. | Requires a U.S. Roaming Add-On with Talk included. Aside from calls to Canada, you will only be able to make calls to people in the U.S. and its territories.
| Requires a U.S. Roaming Add-On with Talk included. You will only be able to receive calls from people in Canada or the U.S. and its territories.
