09-22-2020 11:17 AM - edited 01-05-2022 01:18 PM
09-22-2020 11:46 AM
@irishgirl012 PM is prepaid, so refund is barely possible. However, you can try your chances with moderators. Contact them as was mentioned previously 😉
09-22-2020 11:26 AM
Did you just pay for it or did you use the money on your account to purchase it?
If you just paid but didn't make purchase then you can just leave money there and it will be used for your renewal.
If you did purchase add-on but it wasn't used and is still intact you may yet reaching out to moderators and asking them to revert charges and remove it. No guarantees though.
Was it a roaming add-on? Many people confuse it with regular add-ons
09-22-2020 11:23 AM
@irishgirl012 What add on did you buy? If it's anything other than one of the US roaming packages, it will just stay on your account until such time as you do use it all up. Otherwise, what @Triguy and @BeachNBeer said.
09-22-2020
11:21 AM
10-01-2020
02:57 PM
Luddite
PM is prepaid so usually there are no refunds. You could try submitting a ticket to a moderator.
Here’s how to contact the Moderator Team:
You would probably be better to keep the add-on as it does not expire and will roll over to the next month until it is used up.
09-22-2020 11:20 AM - edited 09-22-2020 11:20 AM
Public mobile does not issue refunds but if you generally made an error contact mods to see if they will make an exception.
Question mark bottom right to open a ticket or private message
