Add-on texts ?
06-27-2018 12:06 PM - edited 01-04-2022 06:18 PM
06-27-2018 01:06 PM
@katiatall wrote:So if one is in a bind there is no options to add texting but to change to another plan?
Wondering if one can renew their plan before it reaches it's term.
@ShawnC13 wrote:
@katiatall wrote:There doesn't seem to be an add-on for just texting but the US Roaming - Unlimited Text (10-day) - $8.00 -Would this add-on do for local texting?
No that is for use on the AT&T and T~Mobile network in the states I believe. Even if it did work and you wanted to for the entire month by renewing it your $10 plan would be now $34 a month when you can just get the Talk and text plan for $25 a month
The option to early renew a plan is available. Simply reach out to the moderator team and they can make up happen.
06-27-2018 12:51 PM
@MacMe wrote:@katiatall wrote:If you go that route you may as well upgrade to a more expensive plan.
I agree 🙂
I don't remember making the above quoted statement today.
06-27-2018 12:47 PM
06-27-2018 12:22 PM
I agree 🙂
06-27-2018 12:15 PM
06-27-2018 12:13 PM - edited 06-27-2018 12:14 PM
@katiatall, I have read online that other customers have tested this US roaming add-on in Canada and found it to also work while in Canada. Having said that, the use of the aforementioned US add-on to address text messaging needs in Canada is totally impractical and not economical. The add-on lasts 10 days and 3 top ups would be needed over a 30 day cycle. The associated costs far exceed the alternative of purchasing an unlimited text feature in a plan.
