Add on purchase
GaryJ
I seem to have bought the same add-on twice by mistake (instructions seemed a little unclear). How do I get one removed?
Daps
These local use add-ons do not expire. So if you plan on using them eventually, you can leave them as is.
PAULRANG18
Only way to have the add on removed would be to contact a moderator by clicking ?, bottom right, and follow instructions. The extra charge could also be left in available funds to be used toward your next payment.
Triguy
If you are having trouble with your services, the next step is to contact a moderator. Here is the link to create a ticket through SIMon:
https://www.publicmobile.ca/en/bc/get-help -> Click on Chat with Simon-on the line "ask me something" write "moderator" -> then click on "account specific question" -> afterward click on "no, I want a human" -> finally you will see an answer "submit a ticket Click me!"
