Add on not working
Yashi
I paid for an add on and it showing active but is not available for ise. Whenever i try to use it, it says u dont have whereas in add ons it shows active. Very frustrating. What to do?
LovesToPM
Yes make sure you have the correct add-on.
Please note that the Roaming add-ons are for use only while you are in USA.
If you need to contact Moderators for help, PM prefers its customers to submit a ticket.
To submit a ticket to Moderators: Click the green question mark at bottom and enter your question into SIMon. Answer the prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
If you encounter problems with submitting a ticket, you can send a private message to Moderators, but this alternate contact method may have longer response time.
@mimmo wrote:
Maybe post a screenshot showing the addons you have
While making sure to edit out, or obscure your personal info....
mimmo
geopublic
@Yashi  If you don't mind me asking which add-on did you purchase?
yanzhiqiang
Send a private message through the following link :
or press question mark at right bottom corner
