Add on not working
Dimitry
Hi There,
I bought an add on for $10 (200mb) the payment was successful I see the credit on account but I can’t use internet
many thanks
8 REPLIES 8
srlawren
@Korth wrote:
@Dimitry
You also have to configure your phone APN Settings to access Data (and msg attachments) on Public Mobile, if it doesn't happen automagically and you haven't already done it.
@Korth that's not always true.  Asus phones pretty much always need manual APN.  But many phones from the likes of Samsung, LG*, OnePlus, Xiaomi, Huawei, Apple, and others come with the Public Mobile APN settings in their factory configuration table.  Some other bands may be hit-and-miss.
*LG phones often have another quirk which require network or factory reset to resolve, but this is unrelated to APN.
@Dimitry
Make note of that because it's the same process for most PM add-ons. Kinda cumbersome, I know...but ok once you remember that it takes a couple of steps.
Good luck.
Dimitry
Thanks so much!!
It's a two step process
Refer to link wetcoaster posted.
cavemantoronto
@Dimitry wrote:
Hi There,
many thanks
Silly system makes you but it again to get the add-on if you have no account funds. Do it again.
wetcoaster
@Dimitry wrote:
Hi There,
many thanks
Adding an add-on is a two step process. First you are adding the amount needed to available funds, then you have to go back and buy the add-on "again".
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974/hig...
hairbag1
Log into My Account. Do you see your payment sitting in Available Funds ? If so, now you must go back and buy the add-on you paid for.
