02-16-2024 02:15 PM
I added an add on before leaving Canada for the US. I waited for it to run out and then did another add on. The second add on does not appear to be added. Not sure what to do. Advice?
02-16-2024 04:01 PM
That’s awesome enjoy your trip!
02-16-2024 04:01 PM
Hi @Linda37
yes, support agent always able to help in case like this. happy that it is sorted Enjoy your trip
02-16-2024 04:00 PM
Yes. They were able to add our second add on quite quickly.
02-16-2024 03:59 PM
Did they manage to help you? I hope so.
02-16-2024 03:59 PM
Resolved. Grateful for this community and Public Mobile's speedy response.
02-16-2024 03:58 PM
Resolved. So grateful for your direction and advice. Thank you very much.
02-16-2024 03:26 PM
Yes you can’t use a new add on right after the old one in case they overlap so I don’t know if they will help you rush it or not. Fingers crossed!
02-16-2024 02:23 PM
Thank you. I definitely do not want to wait and have just sent a note to the agent through the link provided. Hoping this is resolved asap. Thank you for your direction.
02-16-2024 02:18 PM
HI @Linda37
to rebuy the same uS roaming addon, usually you will need to wait 24 hours after the first one expired to re-buy
i don't think you want to wait, so please have CS agent to help without the wait. please submit a ticket with CS Agent here:
