03-20-2019 10:09 AM - edited 01-05-2022 06:55 AM
I purchased a 10 day add on fo US roaming and texting but when I try texting I get a message saying I do not have the add on. Is there something I need to do to make it work
03-20-2019 11:41 AM
Yes I am. I went through the purchase add on process again and it successfully installed. Thanks
03-20-2019 11:27 AM
@Evilone53 are you in US right now? remember US roaming and texting only works when you are in US.
03-20-2019 11:19 AM
@Evilone53 sory to hear that you are having issues. Check you account to make sure the add on is actually purchased. It is a two step process. If you see funds in the account, it means you only completed step one. Second step You need to re-purchase the addon and the money then comes out of available funds. If you don't see money in available funds, you will need to message a MOD for assistance.
03-20-2019 10:24 AM
@Evilone53 wrote:I purchased a 10 day add on fo US roaming and texting but when I try texting I get a message saying I do not have the add on. Is there something I need to do to make it work
Check if you apply to this situation posted earlier this morning. If so, re-purchase the addon ONLINE and ask mods for refund.
03-20-2019 10:10 AM - edited 03-20-2019 10:12 AM
@Evilone53Check your account to make sure it shows the addon, if it does then restart your phone.
To purchase an addon the funds have to be in your account BEFORE you buy it, and it won't automatically take it off your credit card if you have autopay.
