09-07-2019 11:56 AM - edited 01-05-2022 06:56 AM
Does anyone know if this Huawei model could be used in Public Moble Ontario network?
Or how to check its technical spec. competibility to the PM Ontario network?
09-07-2019 01:11 PM
09-07-2019 12:47 PM
@Jb456 wrote:Also think you have a P10 lite not a P20..as googling was-tl10 brings up P10 lites
Yes, you are right. it should be P10 Lite. Thank you for correcting my mistake.
09-07-2019 12:22 PM
09-07-2019 12:18 PM
@Anonymous wrote:So with that reference...the phone won't do any 4G LTE here. Just set it to be able to connect to 3G HSDPA, UMTS, WCDMA whatever your phone says.
Thanks for your advice.
09-07-2019 12:14 PM
Thanks for your prompt response.
09-07-2019 12:11 PM
09-07-2019 12:07 PM
Here's specs of your phone
09-07-2019 12:05 PM
Yes it will work. I'm an a P20 pro right now and also have P20s on Public Mobile
