Add-On Data usage error
adamskip
On December 27 I purchased one GB of Add-On Data. My data history says I used 372.5 of my Add-On Data since Dec 27. Yet my Add-On Usage History shows that I have no Add-On data left. Please explain.
HI @adamskip
actually, it shows clearly about the 30 days:
Data add-ons expires after 30-days
adamskip
That policy change was not clearly conveyed to customers.  And certainly not when I purchased it.  Also, I  purchased a  data add-on last spring and it did not expire after 30 days.
HI @adamskip
yes, that policy was changed around May 2023
and yes, only data add-on as a 30 days expiry.  Long distance add-on remain the same, no expiry and can be used until all used up
adamskip
A 30-day expiry date! That's outrageous. I also purchased a Canada-wide Long Distance Add-on on Dec 27.  Fortunately that hasn't expired.  Maybe that's to come.
Thanks for replying.
HI @adamskip
data add-on you purchased now has a 30 days expiry.  So, if you bought on Dec 27, it would have expired on Jan 26.   Yes, its not good with the 30 days expiry, so just buy enough data add-on for the rest of the cycle, no point to buy extra
