Add 80$ and I need return back
Ahmediq90
Hi
I’m leaving to country and I’m not sure if I come back. I add 80$ and I need return back also deactivation. Please help.
7 REPLIES 7
cavemantoronto
@Ahmediq90 wrote:
Hi
No refunds at Publc Mobile.  Best you can hope for is transfer balance to a friend.
oglat
Hi
If you still have 80 on your account you coould get it back with the help moderators, you should contact them asap
If you have a friend or family on public mobile you could also get moderators to move the funds to them and have your friend reimburse you.
Another thing you could do is get someone else to take over your account for the amount on the account. Just make sure you remove your credit card and your personal information before setting their email address and temporary password.
GinYVR
Sorry @Ahmediq90 but per Terms of Service all prepaid credits are non refundable and will be cancelled if the account is inactive for 90 days.
Triguy
PM plans are prepaid so no guarantee of getting a refund by try contact ing a moderator.  If you have autopay yhen remove your credit card info.
hairbag1
@Ahmediq90 wrote:
Hi
To deactivate your account, just make sure you remove all your credit card info. Then 90 days after plan expires, the account will close permanantly.
As a pre-paid cell service, you'll likely not get a refund of your $80, unfortunately.
Good luck wherever you go.
shskr
Need to contact moderator like the previous person mentioned.
Your account will close after you do not make a payment on your account after 90 days. You also have to remove credit card from account or it keep charging your account.
