11-17-2022 05:38 PM
Can you use a prepaid voucher to activate or only credit/debit?! Can I get a refund?
How long are vouchers good for?
Joining Public
11-17-2022 06:34 PM
The other option is to get one of those visa gift cards to pay. I would prefer that over waiting for support. Then after that you can still use the voucher for the next renewal.
11-17-2022 06:14 PM - edited 11-17-2022 06:18 PM
Simplest way to activate is to have credit card.
If that is not available, ask agent to open you an account and put it into suspend mode. Then log in and pay with voucher.
Voucher do not expire but I would not leave them in my will. Use them when you buy them. Better to have money on PM account than on some piece of paper somewhere in the house...
PM rarely provide refunds; only in case is add-on does not work or PM makes mistake billing you. And definitely will not refund you for purchased voucher.
11-17-2022 05:47 PM
Thanks. Will try it.
11-17-2022 05:43 PM
By yourself - only credit/visa debit. Apparently customers can ask support to set up an account and leave it in a suspended status and then you can pay with a voucher.
Refund for what? The voucher? No.
No known expiry.
11-17-2022 05:42 PM - edited 11-17-2022 05:43 PM
@NoahNameth Voucher has no expiry date
yes, you can use your voucher to activate, but a bit more work
Open ticket with PM support by direct message them. Give them the sim card number. PM support will also ask you for an email address used for the activation. They will activate the account with the sim card but the account will have status SUSPENDED. You will get a login and password. Once the account is setup, you can login and load your voucher to finally activate the service.
Please open ticket with Pm Support by direct message:
