11-17-2022 05:51 PM
So after reading a little further, I wanted the 5 gig plan for $40 with the 12 gig bonus...that's not what I got...I got $40 for 15.. anyhow, I don't know what to do about it so I guess I'll leave it be.
11-17-2022 06:39 PM
Hi Darlene
Did you know should you choose the 12 GB bonus, it will only last for 12 months. Then you will return to your 5GB of data. IMO, for the $40, it will be more economical and long-lasting, if you chose the 15 for $40.
Good luck with your decision.
Tapper
11-17-2022 06:34 PM
@dust2dust Thank you for your note. Sometimes I get carried on... Corrected my post. Appreciated!
11-17-2022 06:32 PM
@Yummy- There is another infrequent user that likes to use that expression towards other customers. Seems many of those posts get removed. I would be fine jokingly saying that to other regulars but I think it's rude and obnoxious towards non-regular customers asking questions. JMNSHO
11-17-2022 06:09 PM - edited 11-17-2022 06:33 PM
You got 15GB forever instead of 17GB for a year. I believe it is a good deal.
11-17-2022 05:54 PM
@Darlene_P Personally, I think the $40/15GB plan is much better as the data will stay the same as long as you keep that plan, unlike the 12GB promo data which would expire after 12 months and then you would have 5GB left in your plan.
11-17-2022 05:53 PM
@Darlene_P $40 for 15GB is better.
the $40 with 5GB + 12GB has a 12 months time for the 12GB. So, after a year, you are down to $40 for 5GB
For the $40 for 15GB , there is no time limit. So, you get 15GB "forever" Honest, I will pick this instead of taking the 12GB bonus
