12-13-2021 09:46 AM - edited 01-04-2022 04:58 AM
Hello I activated my phone and I noticed that my phone number had changed and also that it was not able to make calls I had set up auto deposit and still am not getting service over a month now. Please tell what the issue is.
Thank you.
12-13-2021 07:21 PM
@yodahe01 wrote:Hello I activated my phone and I noticed that my phone number had changed and also that it was not able to make calls I had set up auto deposit and still am not getting service over a month now. Please tell what the issue is.
Thank you.
@yodahe01 - when you log into your Self Serve account, here: https://selfserve.publicmobile.ca/Overview/. check the 4-digits listed under the 'Sim card' selection under the "My Profile" area.
Make sure they match the actual last 4 digits of your SIM card.
If they match GREAT!
IF they do not match, you were a victim of SIM fraud. 😞
List your phone in lost/stolen status.
Check your other financials.
And, let Customer Support know asap.
Two methods to reach them here: https://www.publicmobile.ca/en/on/get-help/articles/contact-a-moderator
12-13-2021 12:44 PM
can you do troubleshoot your device,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck..
12-13-2021 09:55 AM
More details would be helpful.
Did you port your number from another mobile company? or picked a new phone number?
In your self service account, is your account status active or suspended?
Does anything work? text? data?
Which model phone?
Some basic troubleshooting advice:
Reboot phone
Network reset of phone.
12-13-2021 09:54 AM
Did you port your phone number over to PM ? When you log into your account what is the status ?
