11-07-2021 02:14 PM - edited 01-06-2022 03:58 AM
I just switched from freedom to Public. My phone can send/receive texts to/from my other phone which is also on Public but will not send/receive to other providers to take incoming calls. Any ideas ?
11-07-2021 04:45 PM - edited 11-07-2021 04:46 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
for iphone go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your Data is on.
and do again Rebooting your phone means to turn off your phone and turn it back on again.to refreshing your network...
and can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
or maybe you stuck with Transferring your old Phone Number,
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck....
11-07-2021 04:40 PM
More details would be helpful.
Might be a porting issue. If porting issue, you should be able to send texts and call out, but unable to receive texts or calls. If you put your Freedom mobile SIM card back to your phone, does it still work?
Maybe try rebooting your phone. Network reset of phone.
11-07-2021 02:27 PM
Porting a cell number to another cell provider can take 2-3 hours.
INCOMING calls are usually the last to port over.
So if you DID approve the port via a text from Freedom and you are within this time period, it should complete soon.
DO NOT cancel your Freedom account, as a port will not complete if the other account gets cancelled. Freedom account should automatically be cancelled with the port is complete.
11-07-2021 02:18 PM - edited 11-07-2021 02:21 PM
@Charles69 wrote:I just switched from freedom to Public. My phone can send/receive texts to/from my other phone which is also on Public but will not send/receive to other providers to take incoming calls. Any ideas ?
@Charles69 did you reply YES to the Freedom text to approve the port to PM within 90 minutes?
If not, your port could be stuck.
If issues porting or transferring a number to Public Mobile, submit a ticket here for help: https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=1ml7MK2dvkmM37lFcEM...
Also - try one or more of the below:
*turn off your phone, leave off for a few minutes, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings
EDIT: I also private messaged you the Porting Phone Number incase this was an incomplete port.
