12-03-2023 09:03 AM
I used a voucher to top up but my account is still suspended.when I added the voucher it confirmed.I use voucher every month but this time it doesn't work.
12-03-2023 09:47 AM - edited 12-03-2023 09:47 AM
log into self-serve to see if the voucher amount is showing as a recent payment. Sometimes folks enter the wrong set of numbers on a voucher – make sure you’ve entered the correct set of numbers.
If it is, confirm that it’s the correct amount for the plan amount
what do you hear when you dial 611 from your device?
and I presume you are in Canada, right? Not outside trying to use the service…
12-03-2023 09:36 AM
@Afsa You can use this direct link to support to investigate for you
can send a private message To CS_Agents
12-03-2023 09:33 AM
Yes reboot my phone many times and I used voucher 4 days ago. Still not working
12-03-2023 09:19 AM
@Afsa Did you reboot the phone ? Also note some vouchers taken24 hours after purchase to load them
12-03-2023 09:18 AM - edited 12-03-2023 09:19 AM
Then try rebooting your device and resetting network connections
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
