Activation unsuccessful
Shey2
I can’t call call and send messages to my certain contacts I called my previous provider all good transfer and cancellation. Only this Public Mobile data provider have issues please help to fix this trouble issues.
Shey2
Thank you much I took the physical SIM card it is working NOW..👍🏻🙏🏻🙏🏻😂 I appreciate it
Did you remove the previous provider sim card?
slusagm
You cannot call at all or just some contacts?
If just some, test to call them by dialing 1 in front of the 10 digits, also try without the 1
And try Reset Network Settings and try sim using another phone
But if you still cannot make it work, ask PM to check
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link:    https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here:      https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Chalupa_Batman
Hello @Shey2
Try rebooting your phone. If that doesn't work, go into Settings, carrier and find your Network Settings and reset them and then reboot. This should set you up. If you continue to have issues and doesn't work, since you can log in to your account, here is the proper way to send in a ticket.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
