Activation old account
Alexandre8
Hi, I want to reactivate my old account but it tell me esim not installed and i can't do anything.
@Alexandre8
Call 1-855-4PUBLIC to check on the status of your old account.
If the system locates your old number and it is suspended and you need to make a manual payment with the CC on file or with vouchers.
Vouchers can be purchased at these locations:
https://www.publicmobile.ca/en/payment-voucher
If the number doesn’t exist in the system then your account is closed and you need a new SIM and you need to pick a new number. Your old number was returned to the carrier you got the number from. This is due to nonpayment longer than 90 days.
hi @Alexandre8
do you have trouble with 2FA?
click Didn't Receive Code or Resend code and then Send email to get the code via email
if same, ask PM agent to help.
you can submit  ticket by direct message:
slusagm
How long the account was suspended? over the 90 days?
You can ask Public mobile to check for you first
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
