12-23-2021 01:14 PM - edited 01-04-2022 04:50 AM
06-19-2022 12:02 AM
12-23-2021 01:53 PM
@Lunafe wrote:Activation finished but line is not working
We will need more details...
Did you port number?
What your account says? Active?
Does your phone show Public Mobile as provider?
Can you do Anything? SMS, phone, Internet at all?
12-23-2021 01:32 PM
@Lunafe I sent you a private message with the Porting Teams phone number. Incase it's a porting issue. Public Mobile does not want the number posted on the forums anymore. It's in your inbox
12-23-2021 01:23 PM
@Lunafe wrote:Previous phone service provider is cancel and the phone number is been transferred to public mobile but the line is still not working
HI @Lunafe , does your phone shows No service? It sounds like just a SIM provision issue. Open a ticket with PM Support using chatbot: https://publicmobile.ca/chatbot
Follow these these to get to ticket open page quicker:
12-23-2021 01:21 PM
@Lunafe When you activated and entered your phone number to transfer. Was your old provider account still active?. They send you a text that you have to reply YES to too confirm the transfer. Did you go through that step?
12-23-2021 01:19 PM
are you getting new number or Transfer your old number to public mobile, if so
do you get a SMS message from your old carrier asking to confirm if you would like to Transfer your number. Your reply should be: YES.
if you miss it put it back your old SIM card and try to see the SMS,
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
and do some troubleshoot your device,
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone
click Here link,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
12-23-2021 01:18 PM
12-23-2021 01:15 PM
@Lunafe Anything working? Did you bring number from another company or new number?. Make of phone?
