Activation has failed?
07-05-2024 11:42 AM
Hi,
1) Tried to activate yesterday including a transfer of my number from other provider
2) Activation failed
3) Tried to contact customer support / no agents available (multiple attempts)
4) Tried to raise a ticket
Is this the norm for public mobile support?
Joining Public
07-05-2024 12:04 PM
It's possible that you contacted customer support near the end of their support hours, you can try again as they are definitely online. You can also try clearing your browser's or PM app cache etc and try the activation process again
07-05-2024 11:59 AM
still submit the message
they don't reply instantly, it is not a live chat but just messages , almost like email, but they reply quick.
07-05-2024 11:57 AM
They seem to be responding now via above.
07-05-2024 11:56 AM
hi @EdCheng
not hard, just use the link to message support agent .
They will reply shorlty, just check the Community inbox for their reply
07-05-2024 11:53 AM
On the APP it says "SUBSCRIPTION NOT ACTIVATED" - Something didn't go right while activating your subscription. Click below to contact a customer support agent.
07-05-2024 11:49 AM
I did not receive any of that yet. It basically says activation failed and contact a support agent which seems quite difficult to do.
07-05-2024 11:48 AM
@EdCheng, are you able to confirm the number porting completed, did you receive a text from your old company and replied yes? Are you able to make and receive calls?
07-05-2024 11:46 AM
maybe try the message link provided by @hTideGnow
I just tried, seems to be a quicker way
07-05-2024 11:45 AM
Yes I did. They just asked me for my email address.
07-05-2024 11:45 AM
hi@EdCheng
where you got the errro "no agent avaialble"? never seen that. I think you just not open ticket in the correct place
just message support agent here:
07-05-2024 11:44 AM
how you opened ticket?
To open ticket, use the orange charbot icon on the lower right. Start the question Submit Ticket, then choose Contact Us to get to the ticket open screen
