Activation and Number Transfer Issues
Ajang
I am at my final step of transferring my ESIM but the transfer was not succesful. I need help.
2 REPLIES 2
CSA_PM
Customer Support Agent
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
slusagm
@Ajang
if you are at the final step, then it is the activation not successful and not the transfer.
Reboot the phone and login the app once more and check if the app can complete the activation.
But if you get the same error, you will have to ask PM to help.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
