06-18-2023 05:06 PM
Hello,
If I subscribe and order a SIM card today, can I wait to activate the SIM card until a future date that is convenient? I would like to wait until June 29th to "start" my service/billing.
Thanks,
CB
06-18-2023 05:38 PM
Yes, you can wait to activate your plan. A couple things to note though:
1) Your billing date will change month to month, because PM is on a 30 day cycle.
2) The plans available today may not be the same on the 29th when you go to activate.
06-18-2023 05:10 PM
@Cbooth Yes absolutely. You can’t activate until you have SIM card anyways .and the SIM card won’t expire . So you can do it when ever your ready with SIM card in hand
06-18-2023 05:09 PM
To clarify, once I am in posession of the SIM card, it is my discretion when I choose to activate the plan?
06-18-2023 05:08 PM - edited 06-18-2023 05:09 PM
@Cbooth you need the SIM card to activate the plan and SIM card at the same time.
edit - fyi, plans are 30 days not monthly. So it would not be the 29th every month if you did activate on the 29th.
