Activate eSim after promotion
maggiemak
Can I active the eSim with $34 20GB after the Black Friday promotion is gone? Will I still have the plan at that price?
HI @maggiemak
in fact, if you can get a friend to buy you a sim card in person, send you the sim card number, you can then activate it first with the physical sim card
(And for eSIM, if you can download the PM app, you can actually activate it with eSIM using wifi.  Yes, the service won't work, and you might have to deal with it later, but it will activate)
maggiemak
Thanks for the answer. The concern is I am not in Canada until Dec 1st, the time I guess the promotion plan will have gone by then. I don't think I can activate a physical sim card either as I am not in Canada now. Any other solutions?
hi  @maggiemak
if the plan is gone, you cannot activate anymore
is your concern about the eSIM? you can activate physical sim card first and change to eSIM after
is your concern about the eSIM? you can activate it with a phsyical sim card first , and change eSIM after ($5 charges applie
