Accounts
04-21-2023 07:39 AM
I can't seem to get into my account. I'm not having any luck can someone help me please?
My Account
04-21-2023 10:15 AM
I am able to login to My account now. You might want to try again.
04-21-2023 08:59 AM
Yes, look like a My Account issue, I got the same error. Please wait unti it is up again
FYI, My Rewards site is up , My Rewards and My Account use the same logins , so you can try accessing there if you just want to check your password. https://www.publicmobile.ca/myrewards
But of course, if you need My Account only, please wait, it should come back up shortly
04-21-2023 08:56 AM
Is it even a password problem though? I can't get into MyAccount either, it says it's down for Maintenance
04-21-2023 07:54 AM
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
If you are unable to self reset the password, PM support will be able to help
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
